Release 2024.07 Released
keithsw1111
Kellyville, NSW
– enh (joero4) Update ColorCurve dialog to make it easier to adjust near edges
– enh (dkulp) MacOS – Add Shockwave to GPU rendered effects
– enh (dkulp) MacOS – transitions handled on GPU
– enh (derwin12) Lua script updates to allow updating the master view
– enh (scott) Added RGB2Go controllers
– enh (derwin12) Add ability toadd and edit aliases on SubModels
– enh (derwin12) Save and use 3D mode selection in xlight_rgbeffects.xml file
– enh (derwin12) Show any model warnings (missing nodes, etc..) before allowing users to create faces
– bug (dkulp) Fix some issues where Buffer Styles list would not update to syles valid for submodels
– bug (dkulp) Fix disabled effects still rendering
– bug (scott) Fix SVG shape effect (nanosvg update)
– bug (scott) Fix Scripting dialog not working
– bug (dkulp) MacOS – limit number of OpenGL contexts created for Shader Effect, reduce memory usage
– bug (dkulp) MacOS – Fix non-mask transitions not rendering properly with GPU rendered effects
– bug (dkulp) Fix timing of “From Middle” transition when buffer ht is not 1
– bug (dkulp) Switch to sequence tab before loading sequence to avoid a very hard to reproduce/debug crash
– bug (derwin12) Fix crash in DMX Remap Channel Dialog
